What difference does .90 or .13 make
imported_brad
172
Im not up to snuff on my CPU knowledge, and im just wondering what the .90 and .13micro's mean regarding the AMD Newcastles and Winchesters. Do they have performance differences. What's the advantage of one over the other.
Markfw
May 16, 2002
27,427
16,294
First its .09 and .13 , and the .09 (90nm) run cooler, OC better, and are slightly faster due to a couple of core enhancements.
zakee00
1,949
imported_brad
172
lmao :)
thx. thats what i needed to know.
RadiclDreamer
8,622
40
Why quote that? If you dont have anything to add, dont post. I'm sorry, am I ruining your hopes of a higher post count?
Anyway, back to the posters question, there are a couple small differences, the main thing being they run a bit cooler which is a moot point since the A64 runs so cold anyway. They OC well, so if you are into that it might be worth your trouble to find a .09 if not then get whatever you can get cheaper, you arent going to notice much dif
SrGuapo
1,035
Why post thew exact same thing that was posted above? I'm sure zakee just wanted to back up the info, since you don't want to rely on one random post from someone you don't know. You posted almost the exact same thing as the first guy, with some extra crap thrown in. Normally I wouldn't care (since I do it myself occasionally), but don't be such a hipocrite.
MDE
13,199
Actually, it's hypocrite.
postcount++
:p
-Go for the 90nm Winchesters.
zakee00
1,949
yeah really, the whole point in doing that is to "agree" with what that person said.
trust me, i dont give a damn about how many posts i have :p
Ka0t1x
1,724
If this helps at all good, if not, ignore it:
My Newcastle 3500+ will overclock to 2.55Ghz Max.
My Winchester 3200+ will overclock to 2.75Ghz so far ( haven't really pushed it that hard yet. )
And yes, the Winchesters do infact run cooler, and a bit faster, I might add.
