what current socket A mobo's will work with the palomino-?
jamesbond007
5,280
To my knowledge, all socket A boards should handle it fine. I'm not sure if you need the KT133A chipset or not, but I'd stick to the 266MHz bus. I did hear though that the IWill is suppose to support them better because it has more voltage options, which should tweak with the Palomino a tad bit better. I've read in these forums that all socket A boards should be just fine.
Boonesmi
14,448
in a press release it said that most all current socket a boards will support palomino (athlon4)
even the 100mhz bus boards will, but the cpu's will run underclocked.
palomino's "supposedly" will be multiplier locked
