what cpu's will we be using in 10 years?
Cogman
10,284
138
Most likely? I would guess it will be a x86 based CPU. However, we will probably be nearing the limits of x86 CPUs, so its possible that either a new archetecture will be formed, or we will be going to super-sized CPUs (IE Graphics card, sound card, ect integrated directly on to the CPU)
myocardia
9,291
30
I'm guessing in 10 years, we won't still be using x86 processors, even 64-bit variations. I think we'll have reached the limits of what can be done with silicon and copper. Even the EE's usually will admit that anything smaller than 22nm is going to be extremely difficult, if not impossible, and 22nm will be debuting in four years. I can see possibly getting down to 17nm, if they make the transition to laser interconnects, but after that, then what? BTW, ask us this question in 4 or 5 years, and I bet you'll get very different answers.;)
Idontcare
21,110
59
Originally posted by: magnumty
i cant even imagine, 8 cores, 16 cores? it's gonna be wicked.
Well where were we 10yrs ago?
http://everything2.com/index.pl?node_id=1362904
1998 was the year of the 250nm Pentium 2 (Deschutes) and K6-2 (400MHz and 9.4m xtors).
Now we have 45nm quadcore chips with ~730m xtors.
1998-2008
cores 1 -> 4 in 10yrs (4x)
process 250nm -> 45nm in 10yrs (0.18x)
xtors 9m -> 730m in 10yrs (81x)
clockspeed 400MHz -> 3.2GHz (8x)
2008-2018 projected
cores 4 -> 16 in 10yrs (4x)
process 45nm -> 8nm in 10yrs (0.18x)
xtors 730m -> 59.2b (59,200m) in 10yrs (81x)
clockspeed 3.2MHz -> 25.6GHz (8x)
So how does a 16 core, 60billion transistor, 25GHz CPU sound to you?
(what would you do with 60 billion xtors? well you'd need that much to support about 1.5GB of on-die cache and have a few billion left over for your 16 cores of logic)
I likes the idea of such a processor, me hates the prospects of waiting 10yrs to gets.
myocardia
9,291
30
Assuming they are able to get the process node anywhere near 8nm, don't you think they'll be putting alot more than 16 cores in there? We had 4 cores @ 65nm, and we have 6 @ 45nm, and @ 32nm, we'll have no problem squeezing 8 cores onto each die. At that rate, I'm seeing at least 12 cores per die @ 22nm, and 16 cores @ 17nm. Wouldn't that put us @ 24 cores @ 12nm, and 32 cores @ 8nm?
nerp
9,865
105
So how fast will that load Photoshop? :)
myocardia
9,291
30
Even Photoshop CS4, which was just released a day or two ago, doesn't benefit from quads. Maybe by then, though, a quad will be faster than a dual-core, in CS18. I'm not holding my breath, though.:D
faxon
2,109
skynet plz. once we move away from a monetary based economy and to a resource based economy, the machines wont see us as so inferior and greedy after all. the only issue we currently have is where we are going to get the extra copper gold and silver were going to need, since the mines on earth are running low. asteroid belt anyone?
ajaidevsingh
563
If AMD dies due to some reason expect Intel to release 8 core ultra fast 6-7Ghz processor that will only cost $999.
Also dont forget it will be EE. The real dirt cheap $550 processor may have 6 cores an also run at 5-6 Ghz.. Ohh what happy days would that be everywhere intel....!!
PS If AMD goes and sells of it's ATi business guess who will buy it...
EDIT - BTW where are those "But will this run CRYSiS jokes"??
Idontcare
21,110
59
We will never reach the limits of what can be done with the materials science, I can say this with absolute certainty from experience and education.
What will limit how far we go with the materials science though is the financial aspects of the industry.
8nm is certainly possible, but will the revenue (and margins) from the devices manufactured on an 8nm node be sufficiently enticing enough to justify a company (Intel or other) to allocate their shareholder's wealth 6yrs in advance in the pursuit of developing such a node?
For TI the decision was that developing 32nm was not in the shareholders best interest for reasons of revenue ($-volume) and margins.
The financial side of Moore's law is the only thing that will limit continued process technology cadence. We are pretty much in the stone-age when it comes to the materials science we have yet to uncover and exploit IMO.
You're pretty savvy when it comes to computer technology, programming technology, etc, so no-doubt you are familiar with Gene Amdahl's law and the modifications proposed thereafter by Almasi and Gottlieb to incorporate the performance penalties associated with interprocessor communication overhead.
What happens is that while Amdahl's law explains to us why even a theoretical speedup of 1:1 is impossible when the code is anything less than 100% parallelized, the Almasi/Gottlieb part goes further to explain why you can actually see performance decrease (not just stop getting incrementally better with more cores, but actually start to decrease with more cores) if you scale the cores and threads faster than you scale the performance of the interprocessor communications. This has to do with many computer scientists (yes they exist) generically refer to as fine-grained and course-grained applications.
Coincidentally the Beowulf clusters I was building nearly 10yrs ago (1999/2000) had a maximum performance peak on my code of interest (Gaussian 98, a computational quantum chemistry package) of right at 16 nodes (processing cores). Adding more cores, even though the software could scale the number of threads to take advantage of the extra cores, actually slowed down the performance and the entire cluster would take longer to complete its jobs. Exactly as predicted by Almasi and Gottlieb.
What does this have to do with 10yrs from now? My expectation is that we'll continue to see more xtors allocated towards massive shared caches to ensure the interprocessor communications continue to speed-up so they don't undermine the efforts of the programmers to make 8 and 16 threaded applications perform better than a fewer-threaded variant of the same application.
Balance must be maintained in the push for more cores, bigger cores, and more cache. I also wouldn't be surprised if we see heterogeneous cores on-die (both in core size/capability as well as clockspeed). The best way to deal with Amdahl's speedup limitations is to put the serial code on a faster "head" node while farming out the parallel code operations to more numerous but "dumber" nodes.
Kraeoss
450
well nevertheless in 10 years there may be like 20+ ghz cpus going that in only 2-3 yrs we've seen a 1- 4 - 4.5+ ghz steps....
Munky
9,372
The Photoshop version 10 years in the future will still take 30sec to load on that cpu.
aigomorla
21,052
3,533
getting my gainstown /w turbo enabled chips this week.
i'll have 16 simulatanous threads, 8 physical cores, so 10 yrs? try 3 days.
:p
Vaktathi
119
On the raw speed side, I'd be very surprised if we'll see significantly higher raw speeds. There's a reason that CPU's raw speed has been stagnant in the 2-3ghz range for several years after blowing through 450mhz-2ghz in 5 years, there a limit to how fast silicon chips can successfully function in that regard from what I understand.
That said, what we've seen instead is other gains, like the progression to 64bit, multiple cores, increased cache levels, etc that have provided far and away more power potential than simple speed. It will be through other similar advances that we will see CPU's in the future gain power, not raw speed. 256bit processors, 16 cores, and innovative new sets of instructions may be the norm in 10 years, but I also think we'll see some entirely new stuff.
Idontcare
21,110
59
:p
Sure, and when we had our BP6's packing dual-socket and two-cores back in 1999 we thought it was great too.
But look how long we had to wait for the day when we could by two cores on one socket? Nearly 5 yrs.
So how long do you think it will be for us to realistically see 8 cores on one die in a consumer/desktop CPU? Another 5 yrs? Might not be too far off on that. Maybe 4 yrs.
BurnItDwn
26,330
1,841
10 years is after judgement day. We won't be using computers in 10 years. We will be fighting computers in 10 years.
sonoran
174
Probably not nearly as long as you think. But thanks to Amdahl's law, 8 to 12 cores may be an upper limit on what's useful for homogeneous cores.
Instead of, or more likely in addition to, that 8 core CPU we'll probably be seeing heterogeneous CPU designs, with far more than 8 "cores". Just look at the public info already available on Larrabee.
