Greetings
Need a recommendation from you gurus. I am planning to build an HTPC for which I intend to use an ECS G31T-M9 motherboard (below)
http://www.newegg.com/Product/Produc...37&Tpk=g31t-m9
This will have 2G of DDR2 RAM and drive a Gigabyte HD 4350 graphics card. I not yet figured out the CPU but have narrowed down to the Intel Core 2 QUAD Q9550 processor solely because I am getting a good deal [I think].
Question is, is this CPU 'overkill' for this Mobo ? I understand that it is mostly the applications that drive utilization of multiple cores in a CPU etc. and given the fact that the MoBo above is mediocre as well I dont intend to use it for high graphic/CPU intensive gaming, just as an HTPC mostly...... should I not be spending for a Q9550 ?
On the flip side what CPU would you recommend that would suit well with the MoBo and not be an 'overkill' ?
Thanks
Thanks
 Facebook
Facebook Twitter
Twitter
