what CPU and mobo combo shold I use
dragonballgtz
Banned
Mar 9, 2001
2,334
I want to upgrade my CPU and motherboard but for a low cost. Which CPU and mobo should I get. The mobo must be based on the KT133A chipset. I just bought a 256MB SDRAM and I'll be damned if that goes to waste.
MrJ
87
Well, if you want low cost, "low" being a relative term, I will assume you would like to stay under $200 for the combo. I would recommend the Epox 8KTA3+ ($108) and A Duron CPU which can be had for $45-$90 depending on size. Newegg.comhas these parts at good prices.
