What could be causing my power supplies to go?
Jeffwo
Ok...just installed my 3rd power supply (This one was a 300w Enlight, 1st one was a Tiger, 2nd an Enermax) The other 2 ran for awhile and just quit. This one fried upon 1st flip of the 'on' switch.
I can't find anything that could be causing a short (mobo touching case, etc).
Where should I start to correct this problem?
Rig consists of a generic case, Epox 8k7a momo w/1G T-bird, 256 Mushkin PS 2100 DDR ram.
Thanks in advance,
Jeff
I am going to go out on a limb here and say that 300 watts to power that system is more than enough. Unless there are a million-and-one lights, a watercooling setup and you rigged your PSU to power the lights in your office too. I can't even imagine that setup needing 300 watts, much less more than that...
I would start by looking at the possability of bad power from the outlets. If two of them "just quit" after a "while" and this one "fried" that seems more indicative of a larger problem.
\Dan
\Dan
I don't have anything extra on that power supply.
I also have another computer(which has had no problems) running on the same surge protector with it so I doubt it is the power from the outlet.
Anyway, I am getting a 350 watt power supply at the moment and a different case. Maybe this will take care of whatever it is.
Could it be the standoffs behind the mobo causing it? I have never used standoffs but I had to with this case.
Thanks,
Jeff
\Dan
I agree.
I'm running an XP2400@3200 + all the goodies on a cheapo old 300w PSU, and I have an XP1600 on an 8k7a on a 240 watt PSU from an old pentium 2 400mhz.
Check your surge protectors and such...perhaps you have a crazy electrical system?
Definatly not the PSU wattage though.
if something is shorting, the PSU either shuts off immediatly or won't turn on at all, so i doubt it would be something like that.
Standoffs should not be the problem. I have standoffs in all the computers I have ever built (they were needed). Generally, however, if there were to be a problem with the standoffs, my experiences has been that the PC would not power on. I can't see how that would damage the PSU. Much less three of them. Maybe something is unusual in your case, but I still can't see that setup needed more than 300 (quality) watts of PSU.
\Dan
