What cooler will fit on a MSI Pro2A MB?
FloridaBoy3
29
I want to upgrade to a much better CPU coler from the stock one that I got from MWave. Which ones can fit on this board without having to do any mods? FOP 32-1?, FOP 38?, Alpha's?, Vantec? I'll probably buy through 2CoolTek since they are an hour from me. I'm also looking at putting a Sunon fan. Which Sunon fan do you recommend? Quiet, standard, or high capacity versions? I plan on doing some overclocking. But, I don't want a noisy Delta fan. I believe that these HSs' take 60mm fans and not the 80mm size fans (don't want to any mod to the HS). Any advice would be extremely appreciated.
Kenmitch
8,505
2,250
The Alpha PEP66 will fit with some slight mod to it. Pretty much shows what ya need to do to it on his sight. Nice huge sink with lot's of good revues. Not the cheapest choice tho.
hito
261
FOP32-1 and FOP38 uses the same heatsink but different fans. The FOP32-1 works great for me. If you want better cooling and can stand the loud delta on the FOP38, i'm not stopping you from getting it. But for me, i'll stick with the FOP32-1 thank you ;).
- hito
FloridaBoy
112
Thanks guys. I just ordered a FOP 32-1 cooler from 2cooltek. Comes with the YS..... fan. A lot quieter than the Delta, but a little bit noisier than the Sunon. Thanks again for the recommendations.
