timbopoise
I'm in the process of piecing together a 19" Rack mount PC. I have specific requirements but for this post but I
have some questions that might prevent me from going down any rabbit holes.
19" rack mount chassis come with different depths and heights (U1, U2, U3, U4, ec). I'm sure I can find one
deep and tall enough to work with typical desktop PC parts, or at least I assume that, but I'd like to know when
i buy what are typical desktop parts when do I encounter a fit issue?
See brief list of some of my motherboard (MB) requirements below, but questions are:
- Chassis needs to fit the motherboard, power supply (1200W+), cooling system, and possible 2x HDD. How will this constrain the height and/or depth of the chassis?
- I need dual Ethernet ports and maybe good choice for MB might not have extra NIC so I may need to add a card slot. Would standard card fit into a U3 or U4 height?
- As seen from my requirements, I want LGA1700 socket. Do you know of any issues when using this generation of socket with cooler in a chassis, e.g. what height is required for it to fit?
- If you have a recommendation for MB in mind please let me know (brand/model)
- LGA1700, DDR4 >=64GB
- Dual Ethernet
- i7 13700K cpu
- No GPU anticpated
- Raid 0, 1, 5, 10
- At least one Thunderbolt 4 port
- height <=U4 height
- Linux (Ubuntu) all the way!
