what color furniture with oak floors?
Mar 15, 2003
12,668
103
I suck at this and my chick friend's out of town! I need to pick up a bed frame, desk, and dresser tonight - I want the place to look cool, contemporary, and "nice" so I want everything to be coordinated (i'm 24 not 17 so I don't need it to look techie) - what color furniture should I get? the oak is slightly darker than most - between oak and cherry, actually. What do you guys recommend?
Thanks!
White furniture. With red or brown fabric if possible. It'll look great.
jaedaliu
2,670
someone stained your hardwood floors dark? That's pretty hard to believe. I'd put off buying furniture for a few weeks until you get the floors resurfaced to remove the dirt, makes everything brighter, then get furniture.
or, if you're renting or just don't care, get something with a good contrast (i like dark furniture) and make sure you apply felt pads to anything that might touch the floor.
L
Lola
for a contemporary look, go with simple sleek lines and either white OR black. both will look modern. stick with simple fabric patterns (if any) and try a monochromatic color scheme, but dont be afraid to use bright color
KEV1N
2,932
Just pick whatever furniture you like, then get a rug to tie it together.
Mar 15, 2003
12,668
103
Excellent! Thanks. I think I'm going with white, black might get depressing (though it'll look nice).
L
Lola
good luck! anything will really look nice with hardwood floors! what color are your walls by the way?
Mar 15, 2003
12,668
103
They're a light cream/peach almost. I'm so excited about the place - it's a gorgeous duplex with high ceilings and soo much more light than I'm used to!
L
Lola
then definatly go with bright colors or bold colors, especially if you have a lot of light!
Mar 15, 2003
12,668
103
Bold? should I try for lime green? You think I'm kidding? I'm not!
Rudee
11,218
As long as the fabric isn't white, which would be a pain to keep clean.
mobobuff
11,099
White!? You've got the balls to go with white?
Better not let anybody over, or have any parties, or sit on them...
I'd go with red for oak floors. Very warm.
aidanjm
12,411
Thanks!
why do you have to purchase the furniture tonight? why not head to Borders, look at a few books on contemporary interior design? I think you will fvck it up if you buy stuff tonight. :)
aidanjm
12,411
um, white furniture, pretty difficult to pull off if you are an interior design noob, imo..
Fritzo
41,920
2,161
Oak goes well with pastels too if you want some color.
We're getting cherry floors in our new house. Colors are a bit limited with dark wood like that :(
