Originally posted by: Yield
copper does equal copper.. but when there is more copper, it flows better. the longer the length, the more copper you want, too.
better speaker wire can definitely often help noise distortion levels!!!
Originally posted by: NightFlyerGTI
Speaker wire definitly, but a high-quality receiver is probably the main thing you should look for to lose the white noise. That's the only thing I hate about my Sony- really screws up what you're listening to at loud volumes! :|
On that note, what is a good Dolby Digital/dts 5.1 receiver that will not give me a white noise problem? I'm looking at Onkyo, Yamaha, Marantz...
Originally posted by: NogginBoink
C'mon, people! Replacing speaker wire? Puh leaze!
The cause is either the signal source or your amps. Most likely your amps.
The amplifier's job is to take a tiny input signal and, duh, amplify it to a level that can drive the speakers. Along with that gain, it's inevitable that noise is introduced. The amount of noise introduced is one measure of the quality of the amplifier.
If you're using a cheap A/V receiver, manufacturers put in lousy, cheap amplifiers... especially in the rear channels.
If you're listening to stereo music, turn off the rear channels and it should go away.
The only way to get rid of it is to get a better quality amplifier.
(Note that the noise could also be introduced by poor preamps in your source component if you're using RCA (analog) cables from your source to the receiver. If it happens on all sources, it's the amp. If it happens only on, say, the DVD player but not the CD player, it's the DVD player's analog audio outputs that are noisy. But I'm betting it's the amps.)
Originally posted by: p0ntif
Ok, I never notice it when I play DVDs, only when watching TV and having the setting on Dolby Digital 5.1 at the same time. So I usually switch the DSP and it gets better because then I'm actually getting sound out of my rears, but when there is a pause, I notice a hiss. And I don't have a Denon, not really sure what led you to believe that I did.![]()
