What causes flickering vid card/ or monitor?
Stiler
Banned
Nov 21, 2001
1,557
I got some games that sometimes flicker quite a bit, does the video card cause this or is it my monitior? if so how can i fix it?
Adul
44
danny.tangtam.com
it is called refresh rate. You must be running at 60hz while gaming. This usualy can be fixd by using power strip. I assume you are running win2k with a nvidia card
MichaelD
31,528
Flickering can either be due to the output signal flickering, a loose cable or if you have flourescent lights in the room and your monitor refresh is set at 60Hz you'll see the scan lines (or flickering).
Is it only with certain games? What about while emailing/surfing?
Stiler
Banned
Nov 21, 2001
1,557
i'm running on a nvidia card yes but on windows ME.
edit- Never get flickering while surfing, jus in games, i'm experincing it in return to castle wolfenstein, i had some flickering in other games as well.
Viper GTS
38,107
433
Do you run your games at the same resolution as your desktop?
Check what mode your monitor is running in when windows is running (it should tell you the refresh rate), then check it when you're playing your game.
Viper GTS
Stiler
Banned
Nov 21, 2001
1,557
how do i see what its refresh rate is? i know that i have it set to optimal on my video card...
Zugzwang152
12,134
you can check your refresh rate in windows' control panel display. change it down to 60 or whatever the others recommended.
Stiler
Banned
Nov 21, 2001
1,557
i went to that, then advacnded, then adapter, and changed it from optimal to 60khz, still does it, tried 85khz too and it still does it.
yllus
Elite Member & Lifer
Aug 20, 2000
20,577
432
With my 1001st post, I bless thee with a simple point-and-click solution:
Windows 2000/XP NVidia Refresh Rate Fix
My guess is it'll work for WinME just fine as well, because it doesn't seem to care much about the OS when I've used it. Keep us updated if it works out...
