<< If the engine is knocking on 89 octane than the car does require 93 octane, unless you retard the timing/reduce the compression. Short version: engine knock occurs when more combustive force is exerted on the piston than can be controlled. Contrary to popular belief, your car will have more power on 87 octane as long as it does not cause knock/cause the car to reduce its own timing (OBDII). Parts needed: Some cash for gasoline, or a gas can filled with a few gallons of 87 octane. Ratchet wrench, sockets (standard and metric, most likely standard needed), and ratchet extension (Might need, might not, depends on the car), flex attachment (Again, might need, might not) Timing degree ruler (Auto parts store) Marker that is not the color of the car's engine. I like red. To fix the car so that it will run on 87 octane, run the car (nearly) empty, then you need to find the distributor, and retard its timing quite a ways since you won't know its original setting from the factory. The distributor is the piece that all of the spark plug wires run into. Fill the car up with 87 octane and take it back home. Use a timing degree marker to mark off a few degrees plus and minus above center. Advance the timing forward some, rev the car. Repeat until you hear knock (Then stop immediately), then reduce the timing two degrees (To give allowance for the lower octane you will eventually have without the 93 in the tank). Give the car full throttle. If you get no knock, you have cheaply fixed your car and prolly gained some torque/HP in the process. >>
Bullsh1t >>
I agree, you often won't hear knock when just revving the engine; only under a load (like moving the beast while its in gear) will you be able to hear it.
