I order the following upgrades, so far:
-Abit NF7-S 2.0
-Corsair 3200 TWINX matched pair 2x256MB
-2500+ Barton
-Lite On 52X CDRW
-Thermalright SLK-800-U
-Artic Silver 3
-Tornado 119CFM fan @ 56.4dB
I am considering getting an Antec SLK3700AMB, an Antec Sonata, or something else. I need a case that is about 18" high because the space I have for it is only like 20" high and you know that with the rubber "feet" the cases always end up being higher than the specs say. I have thought about the two cases above because I want a case with a front door.
Also, I need a rheobus that is small and can handle a Tornado fan, which runs at 12.5W. I want the rheobus's buttons, or knobs, to fit inside the case with the door closed. I would also prefer if the rheobus uses one of the 3.5" bays, instead of the 5.25" inch bays.
Thanks for your help in advance.
-Abit NF7-S 2.0
-2500+ Barton
-Lite On 52X CDRW
-Artic Silver 3
