Please tell me which power/data cables I need to purchase for the items listed below. Several items are OEM so I know I'll probably need something. The motherboard I have selected comes with: D Bracket 2, Serial ATA Power Adapter, 2 pcs Serial ATA Cables, and Round Cable (IDE?) as can be seen at the bottom of link provided.
Can you please tell me what cables I am missing for a complete setup (HDDs, DVD, Video)?
Do I need extra cables to hook up the front USB/Firewire ports on the case?
Should I go ahead and upgrade the heat sink for the CPU or is the stock acceptable for Non-OC'ing?
I want to order everything needed at once so I don't have to run to the store when I do my build. Obviously, I am not very knowledgeable so if you see anything missing from my list below please let me know what I need specifically. Thanks for any/all help.
MSI nForce3 250 Chipset Motherboard for AMD Athlon 64 Socket 754 CPU, Model "K8N Neo Platinum" (MS-7030) -RETAIL
AMD Athlon 64 3400+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
Corsair Value Select (Dual Pack) 184 Pin 512MBx2 DDR PC-3200 - OEM
Cooler Master Praetorian SILVER ALUMINUM MID-TOWER CASE, Model "PAC-T01-E1"
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only
Seagate 200GB 7200RPM SATA Hard Drive, Model ST3200822AS, OEM Drive Only
Antec 550W Power Supply, Model "TRUE550" -RETAIL
Pioneer Black DVD+RW/-RW Drive, Model DVR-108, OEM
BFG nVIDIA GeForce 6800 GT Video Card with Doom 3, 256MB GDDR3, 256-Bit, DVI/TV-Out, 8X AGP, Model "BFGR68256GTD3" -RETAIL
Samsung Black 1.44MB 3.5inch Floppy Disk Drive, Model SFD321B/LBL1, OEM Drive Only
Microsoft Windows XP Professional With Service Pack 2 -OEM
Arctic Silver Premium Silver Polysynthetic Silver Thermal Compound, Model "Arctic Silver 5", 3.5-gram( 1 cc. ) tube
