I know the battery is a 1500 mAh Li-Ion battery which is standard (original) but do you guys know of a better battery with longer "life" allowing for longer periods without the need to recharge the batteries.
So what do you guys recommend that is better? Should I just stick with the original one?
By the way, I will order the battery from Amazon.com
After some searching....
what about this?
http://www.amazon.com/gp/product/B0...d_t=201&pf_rd_p=1278548962&pf_rd_i=B0088MDQRG
what about this?
