What are your temp differences between CPU and case/system?
Lonyo
I have reported 30 degrees c on system temp, and 55 on CPU, so it's 25 above system.
What sorts of temps are other people getting?
(Stock HS/F and pad on Palomino 1900+)
Total number of readouts: 3256
CPU Speed: 3008 MHz
Running from: 8/21/2003 12:50:05 PM
until: 8/21/2003 5:22:16 PM
Sensor Current Low High Average
Sensor 1 33° C 33° C 35° C 33° C CASE
Sensor 2 42° C 41° C 51° C 46° C CPU
Sensor 3 32° C 32° C 37° C 34° C PWM
To start, ambient temp is 27.2C.....
System 1
XP1700 (T-Bred A) @1878MHz, 1.6V, Coolermaster HHC-001 w/80MM fan
System: 31C / CPU 46C / Diff. = 15C (CPU at 100% running SETI)
System 2
XP1700 (T-Bred B DUT) @2105MHz, 1.7V, SLK-800a w/80MM Panaflo H1A
System: 32C / CPU 46C / Diff. = 14C (CPU at 100% running SETI)
Antec 1040 with very minimal case cooling. Slow fans. (quiet!) XP2100 @ 2100MHz (1.775v)
CPU: 45C idle (34cfm Antec fan on AX-7 HS)
Case: 38C idle
Using MBM while running the Prime 95 torture test
Sensor 1: 30C (Apparently mobo)
Sensor 2: 45C (Socket I guess)
Sensor 3: 59C (Says Diode)
After restarting and going straight to the BIOS my temps say 26C case, and 45C CPU.
BTW, I get annoyed when people use "then" instead of "than" so why don't you change your sig dragonballgtz to:
"Its better to die on your feet,
Than to live a lifetime on your knees."
