Lost_in_the_HTTP
Do you use the ISP's default, or do you set one manually? I've tried both using various public servers and I really haven't seen much difference.
pi-hole.net
You can try DietPi which can run Pi-Hole (or AdGuard Home) along with a lot of other software and not wasting your 8GB ram.I am using this:
Pi-hole – Network-wide Ad Blocking
pi-hole.net
on a RasberryPi 4 8GB, which is kinda overkill as you can easily get away with a 4GB one.
But it works great, especially since it has adware filters on it, and catches some spam.
dietpi.com
Pi-hole is a filter no? I guess it acts as local dns server.
I have internal DNS Servers for resolving my lab gear, but those forward to the Cloudflare DNS Servers for answers they don't have cached.
Yea, it is, but you give it an upstream source for DNS requests. I've been using quad9 filtered for a while, only had a problem once for a few hours.
I use two for redundancy, 4GB models, you could use a 1 or 2GB model with no resource problems AFAICT. The 4GB model runs with low memory usage
I am on pfsense and pfblockerng
All sorts, including pihole ones xdWhich lists?
I'm just using whatever the built in pihole lists are.
We seem to have gone into some kind of phht hole. Are your diet pis cherry or apple?
Meanwhile ....
I try to avoid the Evil G as much as possible. I tried 1.1.1.1 for a while and a few others.
