What are these tires for?
Status
Not open for further replies.
l0cke
3,790
Saw these going through Denver, they are massive
Anyone know what uses these? I assume it's some kind of construction equipment.
phucheneh
7,306
Yeah, I was gonna say 'big-ass construction equipment.' Probably of the dump truck variety...I can't think of much else that scale that doesn't have tracks.
That kind of rubber is insanely heavy and expensive.
phucheneh
7,306
From Wikipedia, on Caterpillar's largest truck:
Each 797 wheel is attached to the axle using 47 nuts that are torqued to 2,300 lb·ft (3,118 N·m).[17] A size 55/80R63 radial tire was developed by Michelin in conjunction with Caterpillar specifically for the first generation 797.[18] The Caterpillar 797B and 797F run on the largest tire in the world, the 4.028 m (13.22 ft) tall, 5,300 kg (11,680 lb) Michelin 59/80R63 XDR.[19] Six tires are required per truck at a cost in 2009 of approximately USD $42,500 per tire.
bbhaag
7,197
2,659
Earth movers man. The things those tires move make the world go round.:biggrin:
BoomerD
65,898
14,296
Could fit a wide variety of equipment, but most likely haul trucks, but COULD be for a large front-end loader.
Different tread than scrapers use. (earthmovers)
Status
