Originally posted by: crazylegs
Step 1:
Remove all dust!
You would not beleive how much dust can ramp up your temps on these cards!!!
Originally posted by: Huskerwr38
My card idles very very high, I don't know why. The temps are around 75 idle and they can get up to around 110 under load. I ordered a Zalman VF 900, hopefully that will help.
Originally posted by: orion446
I had the Accelero X1 and my idle temp was 50c, Before that the stock cooler was 58c.I installed the NV5 rev3 and now my idle temp is 52c.
I figured that since it exhuasted the hot air out the back it might be a better cooling solution. BTW everest records the temp at 43c and the
nVidia utility records it at 52c. What gives?
