What are some good recommedations for center and rear speakers?
DotheDamnTHing
2,795
Slowly putting together a home theater setup..what are some good centres and rear speakers under 500$ CAD?
Tiamat
14,068
If at all possible, you want your center to match your fronts - so shop for the same brand, same class of speakers as your fronts...
Rears... i dont think you have to match them up as much...
Heisenberg
10,621
You should really voice match your center and surrounds to your fronts if you want the best sound.
Anubis
78,712
427
tbqhwy.com
yes match thats what i was getting at, look at whatever yamaha offers for thoes, would be the place to start
that being said mine arnt all the same but work together well
JeffCos
1,615
B&W usually gets my vote unless you wanna spring for Martin Logan's or Vienna Acoustics. They're Relatively cheap for the quality you get and since Lucas uses them in his editing room i'm sure they can handle whatever you throw at them. My friend's whole system is B&W and another friend has 2 of their all weathers. Both systems sound amazing.
EvilYoda
21,198
9
B&W's going to be out of his range unless he considers their entry level stuff, which he shouldn't bother with. Being in Canada, I would consider upgrading from your Yamaha speakers and taking advantage of speakers made in your country like Paradigm, Energy, Mirage.
