- Jun 30, 2004
- 16,117
- 1,728
- 126
eVGA 780i motherboard. It's currently over-clocked to:
E8600 @ 4.25 Ghz
FSB = 1,700 Mhz
Most of the voltages were actually trimmed to lower values or kept the same. Only the CPU and CPU_VTT (CPU_FSB) voltages were increased, but within the spec safe range:
CPU VCORE = 1.34V
CPU_VTT = 1.30V
NB = 1.35V
SB = 1.5V (equivalent to the stock "auto" setting)
All other voltages are set at the stock values shown when the board was running at stock settings.
I'd noticed that OC'ing the board (increasing host frequency from 333 to 425 Mhz) also increased the idle NB temperature by about 2 or 3C degrees -- from about 48C to around 50C @ room-ambient 74F. Now that I've added a new version of the Everest monitoring software, it shows the MCP (SB) temperature idle at about the same value -- 50C.
I was running the X-Plane 9 flight-simulator on the system, and had a "marathon" flight from Las Vegas Municipal (New Mexico) to an air-reserve base in So. Calif. So I was "flying" for more than an hour or so.
When I exited the software and checked Everest on a whim, it was showing the MCP at 56C.
This actually persisted for a bit, and I rebooted to check the BIOS monitor. It returned an MCP temperature of around 52C.
I know these chips are supposed to run a little on the hot side.
What is "too hot?"
E8600 @ 4.25 Ghz
FSB = 1,700 Mhz
CPU VCORE = 1.34V
CPU_VTT = 1.30V
NB = 1.35V
What is "too hot?"
