What are reasons for noise on audio lines?
Comdrpopnfresh
1,202
I'm used to my laptop giving static when I plug headphones into it and use them to listen... but my desktop gives very bad static over headphones too. It gets worse with disk usage and gpu loading... Is this a situation to use one of those ferrite rings to try and cut out interference, or is there another solution to the unknown cause?
mpilchfamily
3,559
This can be caused by a loose connection or a lack of shielding on the wires. But if it happens on both your Laptop and Desktop i'd be looking at the Headset as the problem.
Comdrpopnfresh
1,202
well the static isn't present on the controller headphone port for my speakers. but what could be loose? Used a bunch of headphones- on my laptop I've concluded the noise is simply interference, because using headphones with more impedance cuts it out.
corkyg
Elite Member | Peripherals
27,370
240
And that tends to point to poor shielding of the headphone port circuitry in the laptop. What brand is it?
Comdrpopnfresh
1,202
dell e1505. I'm not so concerned about the laptop- my topic was mainly started to remedy the issue with the desktop. I didn't have the noise on the fp_audio line in my old desktop- though I only used AC'97 and not the azalia (HD) audio. I own a creative X-FI xtrememusic that worked fine in my old system... but not the new(ish) one. Trust me- I've tried nearly everything, and no changes to the system keep that damned sound card from cracking and cutting out- I currently think if I can get this cause of this fp_audio noise fixed, the soundblaster card may work.
Howard
47,982
11
I don't think it's poor shielding, unless he's in an extremely noisy environment. Perhaps the ground wire is loose - I know that can cause a similar problem.
