Originally posted by: magreen
chicken
j/k :laugh:
Now there IS something I would dare not OC out of pure rational FEAR! :laugh:
chicken
j/k :laugh:
Originally posted by: alyarb
do you perform other diagnoses based on attitude?
Originally posted by: SunnyD
There's a reason I usually don't overclock - sure the extra performance would be nice, but when stock gives me everything I need without suffering for performance I don't have to worry about how far my CPU/Video Card/Whatever can go before I blow it up or it is deemed to suck.
The reason: irrational fear of overclocking damaging something
The result: stock performance
the Rest of us enjoy getting results like 4.0GHz from a 2.83GHz CPU - which is *drastic* but completely stable
and i understand the OP's FRUSTRATION that lead to this rant
expect one from me next week - as i try to unlock X550 .. and Overclock
- my *first* AMD system
:Q
New AMD build - *budget* high performance gamer for 19x12
There's nothing irrational going on here. I haven't run into anything yet that requires additional performance beyond what I already have. Of course, I'm plenty happy with 40fps, where 43fps isn't going to make much of a difference for the amount of effort to ensure a stable overclock (in some cases).
Now when I get to the point where I need more performance, then I'll consider it. Until then, it's just wasted effort.
:Q
4.0GHz from a 2.83GHz is going to net far more than 3FPS. Also, you do not need what you have now, the word youre looking for is want. But i understand your drift, its better to OC later in a CPUs life, becuse even if you brake it, you were going to want to upgrade anyway.
:Q
i doubt you will get much support from the guys in OC'ing forum
yes it IS irrational FEAR
:lips:
none of us have it and we don't "blow up" our CPUs and DO get a LOT of *free* and extra performance
you can try to minimize your sour grapes all you want because of your trepidation, but we already know better
I wasn't originally going to post a response to Sunny's original post above on the topic because I thought it would be sort of needless, but given how the thread iterated on his post I will go ahead and weigh in on my thoughts.
Folks here who know me know I was a bit of an extreme overclocker for a while, vaporphase with 4GHz Kentsfield in fall of 2006, etc. So my tolerance for risk probably needs no further elaboration.
That said, I run my desktop rig at stock 2.4Ghz (Q6600) at all times in which I am not expecting to do anything that involves heavy crunching for more than a few minutes (15min is about my patience threshold). When I know I am about to get into some heavy backtesting runs or some lengthy encoding/transcoding queues I OC the CPU to 3.3GHz.
Why do I clock my CPU at 2.4GHz instead of running balls-to-the-walls 24/7 all the time? For me it simply has to do with heat (power-consumption as well as ambient temp impact) as well as noise (the higher OC requires higher fanspeed to keep temps in check) combined with the fact that my computing experience is otherwise identical insofar as I can tell whether my chip is clocked at 2.4GHz or 4GHz when I am doing nothing more intensive than the simple office related application stuff that consumes most of my working time.
I would hardly characterize my personal OC'ing preferences as being driven by "irrational FEAR". And unless you happen to know SunnyD intimately well (heh, my wife doesn't even know my OC preferences), I propose you can't be too sure about the basis of his OC'ing preferences either.
Perhaps you were limited by your video card - or it might have been a game that was not very CPU intensive. i get nice *practical/useful* frame rate increases by Overclocking my CPUNot necessarily. For me, OCing my CPU did nothing but raise my max fps, and avg fps only raised a few. Min didn't budge
Originally posted by: yh125d
Yes I stated I was bottlenecked by my video card, so there was absolutely no reason to OC since everything else I do these days is just NEFing on AT
Originally posted by: Gillbot
I also love it when people read a few reviews and expect their chips will hit the same numbers, especially with completely different hardware. (ie: different ram, mobo, etc.)
I keep harping this over and over but it's true, everyone assumes all Q6600 G0's are an easy oc to 3.6-4.0GHz and as we found out, the later binned chips struggled to get up to 3.4GHz.
Originally posted by: Candymancan21
I really think its your PSU, TBH nowadays if your want the maximum overclocks on a computer with top of the line stuff i wouldnt recomend anything less than 650w, crossfire 850
Originally posted by: farscape
Frustrated - I was. But worse was my attitude. That is not normally me.
i think you are way overstating it
Certified Power supplies - recommended by AMD on their site for CrossFire - are only around 600w
i just got a Cooler Master Silent Power 600w for a Quad Core AMD/4870-X2 PC i am building next week = plenty!!
for single card operation:
http://ati.amd.com/products/ce...wersupplies.html#pstop
for CrossFire;
http://game.amd.com/us-en/cros...ex_components.aspx?p=3
Originally posted by: Scholzpdx
I had my s939 4200+ that only hit 2.4ghz. That's it. Other people on here got up to 2.9ghz. (Eerily similar to Marty502)
I AM NOT STUPID - I've been building PCs for 15 years - But this is throwing me for a loop....
OP - with your stated experience it really boggles my mind that you appear to have expected, as others rightly pointed out above, that ALL cpu's would reach comparable OC's and at comparable voltages and temperatures...
Originally posted by: Denithor
Now, instead of being confrontational here - let's see if there's anything we can do to help you push your OC higher. The suggestion above to isolate to a single stick of memory is a great place to start.
Originally posted by: Rifterut
Sometimes you get a bad chip
I wish to apologize for my rant...
No idea, I haven't really kept up lately with the latest other than the E7x00 chips that people assume will hit 4.4G or so.
This might be true if you're doing liquid nitrogen overclocking. On my E6600 the difference between 2.4ghz stock and 3.0ghz overclock is 10 watts, according to my UPS. I'm basing that on OCCT's PSU test.Originally posted by: Candymancan21
Look at the bold i quoted. Im talking about for overclocking not for running systems on stock... AMD recomendations are for running stock systems. When you overclock your whole system it can use double the amount of power that it would on stock.
But according to Anand's 4890 overclock article (link), the stock configuration was just under 290W. Even if he overclocked that 720 to the point of it needing water cooling, the PSU should still be adequate.The OP is using a 550w Powersupply with a 4890/4gb of ram and 720BE. His cpu is not able to overclock to even the average iv seen on these 720's. I honestly think that psu is holding him back.
Im not sure if this means anything, but in GPU-TOOL during load its telling me the 4890 is using 48-50A of power and on idle its 2A. Maybe thats the problem ?
