First of all, let me say that if you're just trying to share a 'net connection between two houses or apartments, you're pretty much out of luck as far as doing it wirelessly- I think it might be cheaper to have 'em run a fractional T1 or frame-relay out to your house. 🙂 Just a guess...
<< It seems that it mostly deals with stuff that requires a line of sight. Definitly a cool site though. >>
I would wager to say that is likely because anything that can transmit 1/2 mile through several feet steel and concrete (a building) is not priced well for the average consumer.
Most of the stuff that I think would be in our price range works in the 2.4 GHz range. From what I have read, this seems to be a fairly crowded area. If I could find a way to get this to go a half mile, what kind of interferance would I be dealing with?
Well, from what I know of DSSS, it's not terribly prone to interference, especially if you live in an area with few other networks (or expensive portable phones). I've seen some pretty sweet antennae which have a reported range of over 10 miles, but they are highly directional (you have to aim them perfectly) and they can be interrupted by so much as a leaf or some snowflakes (or raindrops).
Eric
<< A friend of mine lives about 2/3 of the way between the two buildings. Could a antenna/booster be placed at his house to help? >>
If you can use his place to construct a line-of-site, then a nice 802.11b setup could be made to work and give all three of you a LAN hookup.
