Sunny129
up until now i've been strictly a CPU cruncher. i use the Windows task manager (the ctrl-alt-del menu) to monitor CPU usage and system memory usage. but i just took delivery of an HD 5870 2GB GPU and have no idea how to monitor GPU usage, GPU memory usage, GPU temp, etc. i have GPU-Z on my computer, but as far as i can tell, it only monitors the GPU core clock and the GPU memory clock. mind you, its currently monitoring an old-as-hell ATI Fire GL T2 GPU, and not my 5870 (i'm on my work PC, and my 5870 is at home and still not installed). perhaps the ATI Fire GL T2 is so antiquated that it doesn't output any more than just core clock and memory clock parameters to utilities like GPU-Z? perhaps i'll see more parameters in GPU-Z once i install the 5870 and start monitoring it instead? or is GPU-Z just not powerful enough software to monitor more than core clock and memory clock, regardless of the GPU used?
i see folks posting all the time in the DC forums about how much of their GPU and GPU memory is being used (in an effort to either increase their crunching efficiency or increase the number of WU's a particular GPU can handle at once), but i'm unclear as to what software folks are using to monitor these things. i searched the forums and got a few hits, but no threads were real clear on what folks were using to monitor such parameters, nor were they clear about what specific parameters were being monitored...any suggestions?
TIA,
Eric
TIA,
Eric
