What are good water filter systems for drinking water?
Status
Not open for further replies.
Canadian tire has a sale right now on them, they have Rainfresh, Filtrette and GE ones. My main concern is quality and also how easy it is to get replacement filters. Ex: will I still be able to in 10 years from now? This would go under the sink and there would be a separate tap, it's for drinking water. Mostly to filter out the chlorine taste in city water. I'd probably coil some pipe inside a mini fridge too, so it comes out cold. The GE model seems to be discounted the most, it's over 100 bucks and right now they're asking 50.
Build your own...
20" Big Blue, with a refillable cartridge loaded with bone char & KDF-55
Or if you want easier... 20" Big Blue with off the self Carbon Block cartridge.
Option #1 = Never having to worry about cartridges being discontinued. Buy bulk media and refill.
Option #2 = Standard 20" carbon block cartridges sell all over the place and will likely never be discontinued.
I don't know what exactly you're talking about, but if it's the type of thing I used to install, you may need to drill through your sink to get a mounting hole for the spigot. That's not exactly fun.
Plumbing is pretty straightforward. Make sure you teflon seal or o ring your new connections. I used to install 3 stage filters (2 particle and 1 charcoal) before a reverse osmosis system. Out came great tasting water, but there are 2 problems.
1) I should have sold service contracts. Filters need to be replaced. I just let my customers take care of that themselves.
2) Reverse osmosis wastes a lot of water. I didn't know how much until I looked at wiki recently. I actually piped the waste water through a flexible tube to the outside. Moved the location daily, and kept my plants watered.
Any name brand reverse-osmosis will do the trick, squirrelster. There are some good ones in the $200 range these days. Over half the houses I've been in since I moved to Canadia have one because the water is not that great here. I think my town water is one of the ingredents in xenomorph blood.
Status
