What are differences between PIxel Shader 2.0 and 3.0
Sable
1,130
105
In PS2 you can shade 2 pixels per 4.7 clocks. With PS3 you can shade 3 pixels per 4.7 clocks.
Also, PS2 requires a badger to be placed under bucket with your XP CD whereas PS3 just needs the bucket and the CD.
Very handy, I was going through badgers at a fantastic rate, although that could have been the water cooling I was using on my bucket.
o_O
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
o_O
Gosh darnit! That's why my PS3 wasn't working! I was using a oppossum instead of a badger!
redbox
1,021
Originally posted by: josh6079
Originally posted by: Frackal
nipples show up much clearer in PS 3.0 pr0n
LOL!!:laugh:
He's thirteen!! He probably hasn't seen those yet!!
I had nipples when I was born. I don't know what is wrong with you freak. :p
BFG10K
22,709
3,007
Larger instruction counts, dynamic branching and higher precision as a minimum to name a few.
dguy6789
8,558
QFT.
For the most part, SM3 simply does what SM2 does in less cycles. There are a very small number of things that can be done on SM3 and cannot be done on SM2, but these situations are very rare.
hardwareking
618
also the visual quality is somewhat better.I've read that somewhere,can't recall where though.
And pixel shader 3.0 does more in less time than pixel shader 2 like the others have said.
And if u want aero effects in vista u need a pixel shader 3.0 compatable gfx card.
ElFenix
102,407
8,595
i like the early morning replies better than BFG's
Munky
9,372
In PS3 you can do something like this:
for(i=0;i<255;++i){
a=...
if(a>4) break;
That's an example of a loop with dynamic braching. In PS2 you'd have to rewrite the code and split it up into several shader passes. So while the same effect could be done in PS2 as in PS3, the PS3 method is easier to code, and may run more efficiently on the hardware.
Barkotron
66
for(i=0;i<255;++i){
a=...
if(a>4) break;
But what about the badgers?
