What are chances of FCpga 667mhz Cel running on 75mhz bus for 750mhz?
SJRoland
19
Trying to be extremely economical around X-mas time here.
Have a old 400 running at 450 on 75 mhz bus for a long time.
Gigabyte GA-6va7+ board
Memman pc133 = 128mb
I never had any trouble running my parts on 75mhz bus.
Just curious about the Celeron chip. I don't know if I
want to mess with 100FSB with higher chip for 800's.
Thanks.
compuwiz1
Admin Emeritus Elite Member
930
I think it should do that no sweat. I have one running at 1000MHz.
There is only one way you are going to find out, that's try it! :)
awise
50
Yea should be pretty easy, I had one running at 1000mhz and it was solid. Make sure you have good cooling though (duh)... :confused:
