Iris Pro should reach GM107 ish, but will probably be a little slower.
Depends on which Iris Pro. GT4e is supposed to have 72 EU, so if it's clocked at around the same speed as Haswell GT3e (40EU) it could be almost twice as fast. That might put it into 650Ti territory, which is starting to creep into the range of acceptable framerates at 1080p and medium settings.
The problem with Iris Pro will remain the same, edram cache tanks at 1080p. Also as soon as texture quality is turned up, we're back to being system ram bandwidth limited, so that hampers any gains in performance. You can cram 10x the EU and it won't make a difference.
Best case scenario is 720p gaming, where it should reach its max perf gains.
Basically suffers the same problem with AMD APUs, its just not viable for 1080p mainstream gaming due to bandwidth limitations. None of these issues will be solved until APUs use HBM for a high bandwidth vram for game assets.
if this can be done, it will be in my next laptop. I don't need high or ultra I just need medium settings for 1080p. a medium gaming latop that weights around 3 to 5 pounds would be heaven to me since I do move around alot.No I really think with the 72EU 9th gen cores 1ghz+ clock 128MB edram on skylake iris pro many games will have playable frame rates at medium settings. As long as the edram cache is smart enough to fill the 128MB with the most important most used data that should help relieve some of the data needed from system ram which should decongest the limited bandwidth by something at least. Medium 1080p for most games should be ok and some games even high may be reached. I'd say many games you'd be able to get medium 1080p settings and maintain a 30+ fps no problem 30 is playable but it is not perfectly smooth i try to shoot for 40+ fps (well of course 60+ on a dedicated card) but for the sake of arguement 30+ stable fps is playable. And this igpu should be having lotsa HTPC living room gamers having fun in 1080.
Not to mention 720p should be good to go for just about any game on the skylake igpu with high-ultra settings and even some aa to help smooth things out on the low resolution and be well in the target 40+ fps.
That should be available right now with a dgpu like the GTX860M. Lower/mid gaming laptops are not really the huge monstracities they used to be. Only problem is the dgpu makes them expensive.
Well if you've noticed the recent rise in vram requirements for dGPU, I don't think a small edram increase is going to cut it in modern games on medium, forget about high.
1080p is still the mainstream gaming resolution and that's where next-gen APUs have to perform well at in order to displace the dGPU in a entry gamer's rig.
It also has to make sense when compared to the cost of a CPU + dGPU combo that gives similar or better performance. If Skylake Iris Pro ends up slower & more expensive, its a non-starter outside of special notebooks.
Intel needs to jump on the HBM tech asap.
I agree that HBM is pretty much a must for future products as long as costs are reasonable. I also hope intel reworks their cache structure.
What I expect to eventually see is HBM used as L4 cache for both CPU and GPU on the same die, just like the eDRAM in Iris Pro except faster and with larger capacity. You might see a standard i5 have 1GB-2GB of HBM on-die, with 8GB or so of traditional DDR4 DIMMs backing it up.
It all depends on price and density. I dont think "combo" solutions will last long, if they even get to appear in the consumer space. With HMC/HBM2/HBM3 you can easily add 8-16GB. And since mobile is king, why even use DDR4 to begin with. We already see a lot of laptop manufactors soldering the memory while using more expensive LPDDR.
Fixed memory sizes for anything but server CPUs is coming fast.
Nonsense.Fixed memory sizes for anything but server CPUs is coming fast.
Nonsense.
