Wh, mAh, V, etc...help a brotha out please
ManBearPig
9,173
So i have to buy a replacement battery for my sisters laptop, which is officially listed as 14.4V x 72Wh. I'd rather not buy the official battery because its expensive and really, really sucks. I have these candidates:
http://www.amazon.com/gp/product/B00...A2ZML8YGZ8CQBA
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
http://www.amazon.com/gp/product/B00...A2M054C9V3EA3L
I can do all the conversions and stuff to get them to Wh like the official battery is listed as, but what I need to know is...would it be better to get a battery with more voltage or more Wh? Or should i try to hit as close to the official spec as possible?
Thanks a ton!
SonicIce
4,771
i think it has to be the exact same voltage or very close. Wh and MaH would be how long it will last. and it has to physically fit etc
ManBearPig
9,173
So should I am for a higher Wh? There's one that's the exact same as the stock battery and a couple that are higher.
SonicIce
4,771
sure, higher would be better. as long as cheap manufacturers aren't overrating them.
ManBearPig
9,173
You think it'd be bad getting 14.8v @ 5.2 amps/hr over 14.4v @ 5 amps/hr (14.4v is tr correct voltage)?
Sorry for the slightly redundant questions, just making absolutely sure lol. Thanks!
Meaker10
370
I have a 9 cell battery, 11.1v, it depends how you connect them too. You must absolutely know the voltage and it must be very close. Also it needs to physically fit obviously.
T2urtle
3,432
on the same subject.
mAh VS cell.
does the one with the higher # last longer? If you had to only go with one which would it be? I've seen some list has higher mAh but the same # of cells. I've always seen higher # of cells but equal mAh
SonicIce
4,771
mAh VS cell.
yeah higher is better. watt-hours is the end all spec because it is voltage times amp-hours. if it says same # of cells but higher mah then either it has slightly more capacity per cell or a knockoff brand that over-rates them. higher # of cells but equal mah, it would have to be a higher voltage and incompatible then. the link in my last post should clear up most of this. i dont have a laptop so i cant say anything about brands but like with AA batteries you stick to the brand names.
Meaker10
370
If I have double the cells but connect each pair in parallel then I would get the same voltage.
So ignore the cell count. Look at the voltage to make sure its compatible (bear in mind that some laptops can take high voltage batteries such as quite a few acers) and get the highest Whr you can.
