WET11 wireless bridge question
Torx2
I am trying to setup a wireless network, so far it has gone great. What I want to do is connect 3 printers to a switch(they all are network ready with rj45 jacks) then connect the switch to a wireless bridge which will be connecting to a Linksys BEFW11S4. Anyone ever tried this or something similar like more than one pc on a bridge, does the WET11 have its own DHCP or will it get IPs from the router?
Yes, that is possible. The bridge defaultly will have a 192.168.1.225 address but this can be changed to either another address or can get an address via DHCP. I have an 7 computer network connected to a Wet11 which then connects to a Wireless router and it runs very smoothly.
The rule is One DHCP to One Network.
If your Router gives the IPs the WET11 should not.
:sun:
