nedfunnell
Hello all,
I've got a BMW 325e from 1985. I have a symptom where sometimes, and I've noticed it more when it's wet, I'll have the engine bog down and give me no power. It happens when I'm accelerating away from a stop- I'll get to about 2000 RPM in second gear, then all of a sudden I'll have no power at all. It feels like there's some serious misfiring going on. If I put the clutch in, the engine will rev without trouble, but getting going is very difficult. If I put my foot into it the engine will eventually get some steam going and the problem goes away once I'm up to speed or the RPMs are higher.
I'm guessing this could be caused by a spark issue. I know that my plugs need to be changed from the way they looked when I pulled them out to do my valve adjustment. I will change those. I am wondering also if the wireset and distributor cap need to be changed too. The ones on there don't look to be in awful condition, but they are an OEM brand so they -could- be original with 160k+ miles. I haven't looked under the distributor cap. The wireset and distrubutor cap are non-trivial in price, so I don't want to go for the 'throw parts at it' method of fixing.
Thanks!
Thanks!
