- Jan 7, 2003
- 83
- 0
- 0
I've been silently lurking, following some of the hard drive threads in case I ran into any DMA problems with my WD 80GB SE. I installed it in my second computer (a Dell 8250, from all those rebate deals) and it seemed kind of slow, so I checked the UDMA settings. It was at UDMA 2. Holy waste of hard drive speed Batman.
Anyway, I removed the Primary IDE in Device Manager, and then rebooted. It seems to stay at UDMA 5 most of the time, except for when I run bootvis (then it reverts back to UDMA 2 for some reason).
Anyway, the problem is that the second hard drive (a Maxtor 30GB ATA 133) always shows up at UDMA 2, no matter what I do. The drives are currently on Cable Select...when I tried installing the two drives as Master and Slave the system wouldn't recognize them. Turns out that Dell's requires you to set the jumpers as CS (at least that's what it said in the user manual).
Does anyone have any suggestions?
-Jennerstein
-Jennerstein
