I have a similar problem (WD800JB) and two different PC's will recognize the WD80GB hard drive under SYSTEM devices BUT will not as a DRIVE under MY COMPUTER.
Here is what I wrote elsewhere and have done to date:
"I bought one of those $20 Western Digital 80 gigabyte hard drives from OM (7200rpm, 8MB cache) and used it as a second HD in my new PC build. Started out with a WD 120GB with Win XP on it, then added the 80 GB Western Digital after I had it all setup and working. Have tried new IDE cables, Slave/Master, Cable Select, cut the two wires in the cable (one at first, then a second), and so on...
And my Windows XP will still not assign a drive ID to it or have it show up under "MY COMPUTER" BUT it will show up under "HARDWARE" in the SYSTEM listing. I have tried uninstalling it, shutting it down, rebooting, cleaning the registry and ALL the above tricks - WHAT am I doing wrong????
My MB is an EP-8RDA+ Rev. 1.1 and has a December 2003 (I believe) BIOS. The system is doing great but will not register the second hard drive, allow me to format it (obviously), or anything at all with it.
I have wasted the last 24 hours on it and even tried a second WD80GB hard drive and it wont work either....
FOLLOWUP REPLY: "I didn't think about dropping the CDRW and the DVDRW drives and adding the WD80 on that cable?/!
I will try that.
I am pretty darn sure though that I have tried the Cable Select, Master Slave, etc., on the other."
SECOND FOLLOWUP: "Well, I tried the other cable without the CDRW's and still no go.
Even tried a second WD 80G HD (brand new) and no go.
Then I tried it in another PC with a different MB - an ABIT - and no go all over the place.
I cannot format what Windows XP doesn't list as a Drive (C, D, E, F, etc.) and that goes for two separate PC's and two new WD80GB hard drives. I am at a loss....
What I also find strange is that the software on CD that comes with the Hard drives will not run in Windows XP Pro, as it crashes. That goes for the downloaded update from WD's site.
How could I get two bad drives....?"
I then read this thread and went to the WD site and tried the different sttings for the jumpers....no go. This is really getting me p1ssed!
Any suggestions?/!
Thanks!
