Went From 53in Rear Proj. To a 42in Plasma
Zorro
2,917
Did i make a mistake. The Plasma has an awesome picture just could not and would not afford to go any bigger. Will i get use to the reduction in size for the quality ?
secretanchitman
9,353
23
what brands were the rear projection and the plasma?
as long as you think and see it as a good picture, then you've made a good purchase.
Feb 19, 2001
20,155
23
EhhI went with a smaller LCD over DLP/Plasma. Could've gone 52" or 56" Plasma/DLP, but nope.. 46" LCD instead. In some ways that does suck, but hey, it's ok.
The only complaint I have is our family room is 25 feet in length. The nook adds like another 10 feet, so watching from the kitchen is almost 40 feet away. 46" looks like a baby from that distance. It's hard to read the news tickers from that distance. Then again I came from a 60" projection TV, and while the quality was sh!t on that, at least I could see, but hey.. HD blows everything away. Being able to go home and watch a footblal game in HD is definitely worth it.
Oblivionaire
253
The right size screen depends on how close you sit to it. So if you sit closer, you should be fine.
RossMAN
Grand Nagus
Feb 24, 2000
79,091
457
We're about 8-10 feet away from the TV, I'm glad we went with 50"
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Yeah, sit closer ftw? :D
Feb 19, 2001
20,155
23
Yea, definitely, but I think the optimal size for a house like mine is like 80", and back when we got our projection TV, such devices would be 10,000 at least, and even now... I don't think we can get a 80" plasma/lcd screen =P
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
Originally posted by: DeviousTrap
Depends on the room size, I wouldn't be able to adjust and would have went with a DLP.
Same here.
