Well that's a first for me, SSD died..
nerp
Here I am thinking it's great to finally move away from unreliable HDDs with their tendency to fail and I buy an SSD that up and dies about 30 days after I use it in a new build.
SanDisk Ultra II SSD 250GB was running great and I was enjoying the speed until Thursday when I powered off the machine and when I fired it back up it was no longer appearing in the BIOS. Did the usual troubleshooting, swapping ports, power cables and even testing in a different machine with the same result.
SanDisk RMA process is underway. In the meantime I ordered a Samsung 850 EVO and it arrived today and the system is back up and running. Windows 10 thankfully is a breeze to reinstall. I save all my working files to OneDrive and my settings are all synched with my MS account so it took me less than an hour to be exactly where I was before the failure.
Now the question is what to do with the replacement SanDisk SSD when it arrives. I suppose I will put it in my aging MacBook pro to give it some new life.
On a side note, Windows 10 activated itself automatically and I didn't enter a key upon install, so it is true that a HDD swap won't break activation on a machine.
Yeah, SSDs tend to fail hard like that, with no advanced warning. Though, to be fair, HDs can also do this as well.
For SSDs, from what I gather, the problem is in the firmware, it gets to a panic state.
I wonder why they don't have SSDs with a 'recovery' switch on them, that can reset the device. Kinda like having a dual BIOS motherboard.
