Well, I finaly killed a CPU thru overclocking!!!!
Beagle
Just one thought: Did you get out your mobo's BIOS buffer battery (if there's one and not a soldered accu) for some time and then tried it again with the insert key?
I had the same effect you mentioned after overclocking my Duron 650 too much (MSI K7T Pro2A mobo). It seemed completely dead, but after setting the BIOS back to defaults by stealing the battery it was all up again and I was able to start over.
Only 2 cents but you never know...
Good luck!
Beagle
voogru
75
LOL;)
I also Have a 1Ghz Tbird and I cracked the core and it still works! does that make a special?!:D
Now that i cracked the core I suppsed theres no use to overclock it. Im thinking bout getting an exchange from AMD but i dont think it will work:( oh well. by the time it dies the 1Ghz chip will be only $80.00
shiznut123
Banned
Dec 22, 2000
2,954
bummer, that was a waste of money.
dang 1350mhz. it could have been a nice chip, but its life has been cut short:(:
