Hi Guys,
My friend brought his PC over and asked for help. It wouldn't boot. I replaced the power supply, and got it to post, etc. The CD-Rom drives won't open though, which makes me think when he PS blew it damaged them.
I hooked up a new cd-rom and it works fine. I hooked up a new hard drive and it works fine, i installed XP to see if it works, and it loaded up and i was able to run prime95 for more than 24 hours. I also ran memtest on it for 24 hours.
He's got some data on the original drive he wants to recover. if I boot into the machine using Winternals, it does not recognize any windows installation. if I boot the the hard drive, it gets halfway through laoding windows then crashes. It just locks up hard.
I tried getting a recovery console so I could run a repair, no luck.
During the Windows installation phase, it does recognize an NTFS installation with a windows folder. It asks if I just want to install it leaving the file system intact or format and do a fresh install.
if I leave the file system intact, will that delete any files in the my documents folder? it shouldnt, right?
