I went to a clients house a while back. she said she was having trouble getting any wireless signal in their house, so they bought a linksys WRT350N router and that helped out with the signal problem they were having.
So I go over there, configure their router and get it all secure, but they have this one desktop computer downstairs that just CAN'T connect for some reason. Initially I thought it was because the antenna was broken (it was pretty bent from the pc being shoved back into a desk), but when I replaced it with a brand new card with an external antenna it STILL doesnt' work.
It'll see the network just fine, and it shows a really strong signal strength. But when I try to connect to the network it will just connect and disconnect every second or so. Looking at it though the wireless configuration utility that came with the new card, it just says "link up" one second, and "Link down" the next. When it shows "link up" it shows the signal strength, signal quality, and noise level and all those look perfect. Until it drops the signal the next second. It happens so quick I can't even ping the router, let alone load a web page.
I even put the old wireless card back in (a linksys wmp54g) and used the antenna that came with the new card and it does the exact same thing.
Here are some even more mind-boggling facts. Her mac laptop works just fine in that area. Connects to the network perfectly, no signal degredation or anything. Also, the desktop PC can connect to this other unsecured wireless connection in the neighborhood just fine, even though it's got a shitty signal strength. It just can't connect to her network.
I changing around settings in the router, different channels, setting it only to use wireless G, etc. Nothing worked, nor would I have expected it to considering three other computers in the house connect to it without issue.
Any clue what it might be?
