When I cold boot w2k from being shut down it boots up and there is no keyboard or mouse. I press the shutdown button and it shuts down. If I boot up and enter win98se first and then restart(without shutdown) and enter w2k everything works perfectly. The only clue I have is I installed w2k before with acpi disabled and it worked perfectly. This install it was enabled. Other than that there is no difference in this install. Could this be causing this problem? If so, how do I get acpi out of w2k? It will not boot if I try to disable it now. I know I can do a repair install but would love to find a way without doing that. Any ideas? thanks
abit bh6,256 ram,pIII 600,ide cdrw,dvd,zip drive, usr pci 56k modem,100/10 lan card,AIW agp vid card,promise ata 100 controller,2 hardrives 18 gig each on the controller, win98se,me,w2k,dos 6.2 dual boot(quad boot) using system commander.
