I accidentally hit the "Power" button under the start menu, which puts the PC in "sleep" mode. The problem is that it did not wake up. The whole system is now dead. It will not even boot.
I've tried about everything, short of replacing parts. I was pretty sure that resetting CMOS would work...nope. I guess I'll replace the PSU and try again.
