i installed omega driver today and it said the card's memory is 337.50. I check on new egg and the card came with 680mhz spec. for speed. Is that right? and what should i do?
thanx for any help
misleading DDR again........it is clocked at 340mhz.....but the ddr effect is this....it can read and write on the same clock, so effectively its like having 680mhz SDR (single data rate .... can on read or write, not read and write)
