Weird Temps on 3.oc
dz1
ok i need some expert advice. ok heres the scoop my 3.0c running stock speed with intel stockHSF was in the 49-50c on load with occasional jumps to 53c but ran steady at 50-51c running dual prime 95 s and mobo temps stayed farily low 28-30c durring prime 95
so i bought a SLK 947u and installed it with a 80mm thermaltake smart case fan II the CPU now runs with dual prime 95 s may reach 40c which is great but her is the problem at idle mobo an CPU temps are both at 27-30c can anyone tell me where the temp reading for the mobo is comming from?? oh yea i have 5 80mm fans for the cas 3 input fans and 2 exhust plus the 2 exhust PSU fans i have tried nnumorus ways with case fans no diffrence in mobo temps so i dont think air flow is it also i cant get the smart fsn contoller to work right min fan speed is 4500 rpm and max is 4780rpm i need help on fan themorister and mobo temp any help on this subject would be greatly appreciated oh yea case is a antec 1000 plus view and psu is a antec true power 550watt
