Ok, I just put a system together... here are its specs:
Antec ks188 w/300w PS
MSI k7pro
700mhz TBird not overclocked
couple of PCI cards, tnt2 ultra
Case is currently open on one side and the top.
Processor has a RDJD701 with supplied thermal tape (i am getting some paste soon, I just wanted to test with the tape).
One 80mm fan blowing in at bottom of case in plastic bracket.
Now here is where I am confused.
The chassis temp is always 2 degrees warmer than the CPU. Right now the chassis is at 39 and cpu is at 37 C. I'd figure the CPU would get pretty hot since the tape isnt too great a conductor of heat to the rest of the case...
What gives? 🙂
or are MSI's readings wrong?
MSI k7pro
What gives? 🙂
