- Nov 17, 2014
- 2
- 0
- 0
Hi there! For the past few days im having some problems with playing games. For some reason, every 2-3 minutes I will get crazy lag, and it will stop. You can see it at around 0.50. What happens is, my character just teleports in all kind of directions and places for a few seconds before returning to the original spot. This has happened in Battlefield 4 as well as in FIFA 15, where the game would stop, and then it would pretty much fast forward. This is really game breaking for me as it will happen in moments where I need to be spot on. For instance, when im in the middle of a 1v1 duel in CS:GO or when im about to score a goal in FIFA 15.
Extra info: I did some troubleshooting on my gpu, cpu and memory and found no problems with them. Another thing I noticed is, just after this sort of lag happening, my ping would jump from 24 to 80 in just 1 second, then slowly fall down. It also sometimes goes from 30 to 150+ in 1 second before slowly dropping. Also I have A router and a modem. The modem uses its own internet and I use it for wired connections like my computer while the router's network is used for wireless connections like my phone.
Here is a video I recorded to show you what happens: https://www.youtube.com/watch?v=7F9PrKITnn4&feature=you...
Fast forward to 0.50 to see the problem.
Thanks in advance! :wahoo:
Specs:
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: MSI
System Model: MS-7798
BIOS: V1.6
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 8126MB RAM
Page File: 2864MB used, 13966MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
Card name: NVIDIA GeForce GTX 660 Ti
Manufacturer: NVIDIA
Chip type: GeForce GTX 660 Ti
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1183&SUBSYS_128019DA&REV_A1
Display Memory: 4037 MB
Dedicated Memory: 1989 MB
Shared Memory: 2048 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Specs:
BIOS: V1.6
Memory: 8192MB RAM
