- May 19, 2011
- 20,378
- 15,068
- 136
I'm putting a new disk in a system after the old disk has died.
After Vista 32 SP1 setup, the system seemingly hung on a black screen saying "Please wait while Windows sets up your computer", so I reset it. It seemingly paused a long time again at a different point of booting into setup but I just left it to it and eventually Windows booted.
In the logs are lots of atapi controller errors pointing at the disk (I temporarily disconnected the CD drive and the problem still occurred). Vista SP2 install failed the first time but worked the second. Windows Update consistently fails on error C80003FA which also suggests disk I/O problems.
I know that the original VT8237 south bridge had problems with SATA 3Gbps (in my experience, the BIOS doesn't detect disks at all), and of course this disk is SATA 6Gbps. I have tried putting a jumper to force the drive to SATA 1.5Gbps but it hasn't helped.
There aren't any BIOS updates available for the board, so there goes that option. I tried VIA's chipset and SATA drivers, but the system seemed to misbehave even more (non-responsiveness for 30-60 seconds when right-clicking on the taskbar, things like that), so I removed the VIA SATA drivers.
Of course, it might be a disk problem. I tried a short test with SeaTools for DOS on the disk which came through fine, but I thought I had a better idea rather than run the long test straight away, which I'll end up doing.
The old drive's model is: WD3200AAJS. I haven't found another source confirming what SATA spec it adheres to, but ebuyer.com reckons it is a SATA 3Gbps drive, which surprises me.
Any suggestions would be much appreciated.
- edit - the disk just passed the long test on SeaTools for DOS. I'll try memtest86+ just in case.
