I have had many many autos (had used car dealership for 7 years)
and have never experienced noise from the steering column :Q
Course I don't think the golf is a good car either
Good luck p.s. I'd call the VW dealer and talk to someone in the service dept as
to the incidence and frequency of this problem
I suspect it is a VW glitch
Steering:
Steering input shaft joint loose/rag joint deteriorated?
Steering box tight to chassis?
Steering box shaft seals leaking?
Rack and pinion unit mounting bushings deteriorated?
Rack and pinion unit boots torn?
Rack and pinion unit seals leaking?
Play/lash in steering box/rack and pinion unit?
Play in tie rod ends?
Play in pitman arm?
Play in idler arm?
Play in rack and pinion inner socket assemblies?
Power steering fluid lines/connections leaking?
Power steering pump belt loose/worn?
Power steering pump reservoir fluid level low?
