Long story short, I used distilled water in my water cooling system then later switched to coolant. I just drained my system for travel and saw that there is a residue building up in the tubing but not in the blocks. Any ideas on what it is and if I should be worried?
It is from the coolant, which coolant did you use? It won't bother your system at first but must be flushed out when the blocks start to clog. When the temps start to rise it's time to tear down.
I had some weird residue once when I was using distilled water and D-tek additive and I just ended up throwing the Tygon tubes away. I'm using PC Ice coolant now and don't have that residue.
