- Sep 6, 2005
- 3,822
- 1
- 81
My RC-690 has been working flawlessly and silently except for a bit of a buzz coming from the case. I traced it down to the side panel fans. I'm using regular Cooler Master 120mm fans on the side. What I noticed is that having an intake fan on the side creates a loud buzz, the single loudest noise on the idle system. I'm wondering what is causing this buzzing?
It's definitely not the contact, I can still hear a small amount of buzz if I manually hold the fan about 5mm away from the grille. I think it may have to do with the airflow going through the grille, but I'm not sure, and I don't want to make a drastic change to the case either. But this buzz is driving me nuts.
Does anyone else have this issue?
It also doesn't buzz if I use a fan controller, so I assume it might have something to do with the speed of the air or the rpm of the fan. I can't use a fan controller with the side panel fans because the cables are too short.
How can I fix this? I'm not sure if going to quieter fans will help because these fans are pretty quiet when not near the side panel.
