weird ram problems
oddlink
well if any of you saw my thing dealing with uv paint on video cards or ram, it has been fixed thanks a lot
anyways, i got a little weird problem going right now, i had two 256 rams, and i bought two more of the same thing, but the problem is, after a lot of alcohol cleaning and whatnot, for those of you who dont know, my computer was not working for a while
anyways, the two old rams, they work as singles, but not at the same time, the machine just doesnt turn on, the new ones work fine together, but as soon as an old one is put in there, it doesnt work?? any idea what that is about??
it worked before, but after cleaning it, it doesnt anymore??
Update:
i gave the ram another cleaning withe alchohol, fixed them up, now i got my 1 gb of ram
